Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
Daughter's z50 quad - NO SPARK
Old Apr 24, 2015 | 10:21 PM
robdnice's Avatar
Default Daughter's z50 quad - NO SPARK
Hi guys! Brand new to the forum and I've been doing some great reading on here. But I can't seem to find what I'm looking for. I picked up a 2006 Suzuki LT-Z50 for my daughter and I am running out of brain power.....
The bike has no spark. I've purchased a factory service manual and followed all of the trouble shooting guides. Previous owner had some time in it and supplied a new coil and a new cdi box.
After following the trouble shoot guides and using a fluke test meter I thought I had figured out the issue. So I replaced the stator and pick up coil assembly. No changes! If the parking brake is not set, no crank. If the killswitch is not set, no crank. If the tethered kill switch is not pushed in, no crank. So I am "assuming" these connections are good. I don't know what else to check.
Any guidance or help would be greatly appreciated.
Thanks,
Bob
Old Nov 15, 2015 | 06:40 AM
wishmasstir's Avatar
Can you post the specs for checking the coil and stator? Anything else that can be checked/measured on these atv's?
Old Nov 17, 2015 | 03:59 AM
Sorry if this is the same as the checks in the book, but from the diagram, the wires to the CDI are:-
O/W Is live through Ignition switch + remote switch + stop switch.
W/B Is live when parking brake is on.
R/B Is live when the starter button is pressed.
Black goes to the ignition coil and should pulse positive at ign coil.
B/W Is negative from battery.
Brown picks up a signal from trigger coil in alternator, should pulse positive.
Apart from the brown wire and the black, all these wires should get a full 12v so may be best checked with a test lamp to ensure you are getting power as well as volts to them.
Old Nov 17, 2015 | 09:46 AM
Zrock's Avatar
Super Quad Patrol
Check the back of your key switch. i have seen them where the wire was only holding on by a thread.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
tweeder
Jul 5, 2015 01:57 PM
D-Hagz
Jul 4, 2015 02:19 AM
jag6510
Jun 15, 2015 05:59 PM
