ATP 330 oil change
Old Apr 29, 2015 | 10:37 PM
cornermike's Avatar
Default ATP 330 oil change
Friends that I camp and ride four wheelers with have a 2004 ATP 330. Since they are not too mechanically inclined, they asked me to change the oil in it for the summer season. Is this machine similar in service as the sportsman 500 as in you drain the tank and the lower crankcase, pull the fitting on the tank to clean the screen and prime the pump after the oil is added? They picked up the oil change kit so I am assuming it take 2 quarts like the 500 does. I am going to grease it while i am at it also, are there any hidden fittings I should be aware of?
Thanks,
Mike
Old Apr 30, 2015 | 07:03 AM
Yooper265's Avatar
No seperate oil tank like the 500 , just drain the crankcase and change the oil filter , it's a easy job . Lots of grease fittings , just check everything that moves , driveshafts , a arms , etc .
Old Apr 30, 2015 | 11:05 AM
cornermike's Avatar
Does it have the same capacity as a 500? The filter is the same and the kit came with 2 quarts.
Thanks,
Mike
Old Apr 30, 2015 | 11:15 AM
TLC's Avatar
TLC
Here is a video on the 330 motor oil change.
Old Apr 30, 2015 | 11:34 AM
Yooper265's Avatar
Yes , two quarts of oil .
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Alex G.
Sep 11, 2017 11:38 PM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
