2013 sportsman 850 xp le
Old May 7, 2015 | 07:29 PM
EPOLARIS850's Avatar
Default 2013 sportsman 850 xp le
Its fine when im riding hard but sometimes when I let off the throttle it will bog out . It shows a code on the instrument panel. Looked it up says throttle stuck . Was wondering if anyone know what could b causing it and how to fix it.
Old May 7, 2015 | 07:56 PM
Weird code,plus usually goes into limp mode.From all that I've read the fix to this is installing a 2014 tps sensor.. Read where guys have zip tied back the contacts in the throttle housing or blocking the contact points as a temp fix. There's about 17 pages on the other forum on this problem. Here's one of the posts:"Yep, my friend got his 2013 850 back as well. They put a Throttle Position Sensor that is on the 2014's on his. He's ridden 30+ miles no issues.
The 2014 part number is: 2412634" Plus here's some of the other posts on this.. Check engine - stuck throttle cable - Page 11 - Polaris ATV Forum
Old May 7, 2015 | 08:03 PM
Ok thanx
Aug 21, 2015 01:23 PM
DFWSRT8
Aug 20, 2015 09:24 AM
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
