Outlaw 90 spring removal
Old May 8, 2015 | 09:06 AM
Mark84's Avatar
Default Outlaw 90 spring removal
Maybe im missing something easy here, but how the heck do I get the springs off of the shock? I have the whole assembly off and want to remove the spring
Old May 8, 2015 | 09:53 AM
Save yourself some grief and just take the shock to a good cycle shop that can do this in 5 minutes and very like likely charge you peanuts for the job.Or if you're determined to do it yourself,possible area auto stores have small enough spring compressors that you can "rent". This is the one I had at the shop.Makes short work of spring changes.Just clamp the bottom into a vise and compress the spring enough to slide the retainer off.
Attached Thumbnails Outlaw 90 spring removal-race_tech_shock_spring_compressor_detail.jpg
Old May 8, 2015 | 09:58 AM
Mark84's Avatar
I got it taken care of, but thank you anyway. So remember the clutch issue I was having the other day? I got a service manual and got it all figured out. The primary clutch was stuck, got that all apart and fixed up. Also, the bearing in the crankcase for the shaft for the secondary clutch was bad. As well as the oil seal. Got the new parts on the way from cycle parts warehouse. Thanks again for your help!
Old May 8, 2015 | 10:13 AM
Don't thank me ,thank the manual that can solve most of your problems.. This why I push em on people all the time that want to do their own repairs/maintenance..
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Divergent12
Dec 30, 2017 08:33 PM
merryman
Jan 19, 2016 04:29 AM
1000gade
Aug 19, 2015 07:10 PM
ghost civic
Jul 27, 2015 03:15 AM
