Redcat, wire identification
I'm working on a Redcat for my neighbor. After flushing the tank, cleaning the carb, and fixing the coil wires, I got her to fire up! I'm concerned about some of the wiring however. The following pictures are all the "loose ends" up front.
Picture 1 is the coil wiring I fixed
Picture 2 shows the Neutral indicator wire and what I believe to be the Reverse indicator, the N wires are torn but tested positive when I shifted, the R has a holder and bulb but I think the bulb is bad
Picture 3 is the headlight wiring (I think in the case of the torn wires)
Picture 4 shows 2 wires that I don't know what they are (what else is up in the front?)
Does anyone have a wiring chart? Tech manual?
While it was running, the cooling fan never kicked on, how do I verify that system is working, is there a thermostat?
Again I stand corrected. I was pretty tired while posting last night. The mystery wires are actually part of the indicator light bundle BUT the shroud only has 2 indicators so what could that be?
What are people doing to replace headlights? I don't think $50-$60 per assembly is very cool.
You can usually find the assemblies a lot cheaper on ebay. Just search for the redcat headlight and save it. Eventually someone will part one out somewhere. If you don't ride at night, then I would move on. Or you can fab up something with LED's.
