89 polaris trailboss 250 rs/e rear brake
Old May 18, 2015 | 11:29 PM
punkmunke's Avatar
Default 89 polaris trailboss 250 rs/e rear brake
i bought the quad in pieces and have had to re build assemble it.
oil pump is bad and i would like to rid myself of that and do pre mix
is there a kit i need or just block off the line?
also the most important piece of information to me is assembling the rear brake. it appears to be a small disk with a caliper and pad under the right rear fender that sits on a spline. what are the steps to assembling this. it baffles me because nothing seems right with this set up
any help at all is appreciated
Old May 19, 2015 | 09:18 AM
You can drain the oil tank,remove the small hose from the pump to the injector at the cylinder base and cap it off. Premix 40-1. This is the cheapest way and you can still use the split throttle/oil pump cable. If you want a block off plate,they have them here,but best to change to the single throttle cable.Aaen Performance - Polaris ATV Two Stroke - Top End Pipes Plus you can make your own block off plate to save some $.
This is the old style rear brake if you have it.Shows that the rs/e was made up until the 88 model year,the rear brake was a updated to the adjustable mechanical/hydraulic type,but I really can't remember.Hopefully the parts bread down can help you on assembly.http://www.cyclepartswarehouse.com/f...1989&fveh=5336
toonces
Oct 16, 2019 12:11 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
