gas leak 2001 magnum 325 need help.
Old May 20, 2015 | 10:50 PM
Big600twin's Avatar
Default gas leak 2001 magnum 325 need help.
I recently bought this used for my daughter. I have been hiding it in my shed until her birthday in a few weeks. When I bought the machine it was almost out of gas and it had to be on reserve to run it. I just filled it up on Saturday and today when I went into the shed it stinks of gas.there was a huge spot on the floor and almost all of the gas is gone. I couldn't find any clean spots that would indicate where the leak is and I haven't had a chance to fill it again to try and locate it but I was wondering if there may be something to look for that may be an easy fix. I read about a gasket by the shut off valve or maybe the fitting under the tank. I'm really hoping there isn't a hole or crack in the tank. i am not sure if the tank can be pressurized to find a leak?? Any help would be great. I am calling the dealer I bought it from to see if they will help because in its current condition, it should be ridden. I am really bummed and I need to fix this soon. Really don't want to disappoint my daughter. Thanks!
Old May 21, 2015 | 07:10 AM
1ArmBandit's Avatar
id start by putting some more gas in it to see where the leak is coming from
Old May 21, 2015 | 09:59 AM
Pull the dip stick and see if it's over full or the oil smells like gas. If it does,needle and seat could be sticking,leaking out the overflow and into the engine.http://www.ebay.com/itm/Polaris-Magnum-Boss-325-2000-2002-Carburetor-Rebuild-Kit-Carb-3131363-522-/231539134633?hash=item35e8ced0a9&vxp=mtr
Old May 21, 2015 | 10:08 AM
Big600twin's Avatar
I will check that tonight but I was wondering if it would leak like that just when sitting??Sorry carbs not my thing. If I fill it back up what would be the best way to see if it is an issue with the carb?
Old May 21, 2015 | 10:14 AM
Put some clean paper towels under it when you put in a little gas or just feel the carb over flow tube at the end to see if it's wet. The 325 doesn't like gas in the oil for sure. I've had to rebuild several cranks because of this.Be sure to check the oil level and smell for gas.
1ArmBandit's Avatar
Pull the dip stick and see if it's over full or the oil smells like gas. If it does,needle and seat could be sticking,leaking out the overflow and into the engine.Polaris Magnum Boss 325 2000 2002 Carburetor Rebuild Kit Carb 3131363 522 | eBay
was going to mention that too, but didnt think the gas would flow thru the fuel pump...
Old May 21, 2015 | 10:18 AM
Thought so too,but if the needle and seat are sticking it can pull a vacuum of its own into the carb and engine and contaminate the oil. That's why I've had rods thrown on the 325 before.No other Polaris engine really had this problem.
Old May 21, 2015 | 10:23 AM
1ArmBandit's Avatar
so the 500s are ok to leave the gas on? ever since i got my 500 ive been not shutting the gas off because its kind of a hassle lol
Old May 21, 2015 | 10:35 AM
Imo if any machine has a fuel shut off valve use it when you're through for the day. I had to really preach this to people especially on the old 2 stroke machines that it was a straight shot from the tank to the carb if the needle and seat were bad.I didn't like having to drain crank cases on top of rebuilding carbs. Most problems on the 325 were the first two year models (2000-2001) on throwing rods. Almost everyone I had to rebuild,the oil was contaminated with gas.Like I mentioned the 325 was the only one that really was bad on this. Possibly because of the car type crank shaft and thin rod bearings.Guess I'm a little paranoid on this from previous experiences.. The 325/330 were good engines and we sold quite a few over the years,but when I hear about leaking gas from one I freak..
Old May 21, 2015 | 10:55 AM
1ArmBandit's Avatar
ive always shut mine off till i got the 500, its just in a position now that when i get it in the shed i cant reach it(have to climb off the back to get out lol) but im just gonna start pushing er in after shutting the gas off just in case...and i know what ya mean with the preachin lol im always the one telling my buddies to turn their gas off and when they catch my quad sitting with the gas on i hear about it for the next week haha im slipping!
