spark plug wire
Old Jun 14, 2015 | 12:42 PM
DOC HOLIDAY's Avatar
Unhappy spark plug wire
hello all,my 2013 sportsman 500 has a bad sparkplug wire.the wire is pulled out of the red boot,i was just wondering is it possible to replace just the wire or do I have to buy a whole new plug wire and coil,they are over one hundred dollars from the dealer.thanks
Old Jun 14, 2015 | 02:17 PM
TLC's Avatar
TLC
I never changed a spark plug wire on my ATVs but have on my sleds and all you do is shove the wire back into coil by sliding the boot up the wire then shove the wire into the coil's wire hole.
Even when you buy a new coil some make you install the wire yourself. Pulling the wire out of the coil or spark plug cap can't hurt anything.
Old Jun 14, 2015 | 05:27 PM
Just get a length of 7mm coil wire and silicone the wire and boot and twist it back into the coil. Had a recall on 2007 model Sportsman 500s that wires could pinch between the tank and frame from an assembly error and many did and would die in their tracks. Polaris just said replace the coil assy. I just pulled out the bad wires replaced them and rerouted them. They even make coil wire splice kits for sealed coil wires that had bad spots in them so you could save the coil.http://www.ebay.com/itm/NGK-SPARK-PLUG-Wire-Cable-Splice-Connectors-7mm-Wire-/311196846125?hash=item4874c7082d&vxp=mtr
Old Jun 14, 2015 | 06:52 PM
Default spark plug wire
the spark plug wire just pulls out of the spark plug boot and it appears it was not connected in the boot to the plug clip,is this how it should be or is it broken ?
Old Jun 14, 2015 | 07:07 PM
Just screws in if that was all it was. Use a little electrical grease and screw the plug cap on tight to the wire. Plug cap has an inner barb that screws into the wire. Item#2.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Jun 14, 2015 | 07:25 PM
Red face plug wire
That's opt,my atv died out yesterday everytime I got it wet going threw puddles and i was trying to figure out the problem and i noticed the plug wire seemed to be almost out of the boot and thought that was the problem,
Old Jun 14, 2015 | 11:56 PM
That could do it if any amount of moisture could get into the cap and short the connection.Just use some dielectric grease around the cap and a little dab inside once you get the wire secured.
Old Jun 15, 2015 | 05:00 PM
Smile plug wire
Thanks opt,you have been a big help.
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
D-Hagz
Jul 4, 2015 02:19 AM
