CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
mvwhite
Old Jun 28, 2015 | 12:18 PM
mvwhite's Avatar
Default mvwhite
Put next axle bearings and seals in yesterday, first time doing it on a four wheeler, put bearings in and tapped seals in place, put everything back together , test ride it and the seals come out. Is there something that keeps seals in place? Any help would be appreciated. 2003 ds 650 baja
Old Feb 25, 2020 | 07:00 PM
CP8NT's Avatar
Default Seals
There is in my experience a point at which the seal should seat in and then won't or shouldn't move. I would check to ensure seals and bearings as well are fully seated in their respective position or groove. I used a jack to make sure they were seated in position. Once the thing is seated it shouldn't slip or come out of position. Especially if locked down right into place. Was there drag on the tires or any sense of resistance besides expected minute amount thatay be due to breaking in?
Old Feb 26, 2020 | 08:54 AM
Zrock's Avatar
Super Quad Patrol
what he said... sounds like they did not get in all the way, wrong seal, or when cleaning up the parts you took of to much material where the seal sits. If the seals are right and you did have them in all the way you can try a little green loctight. It takes up small gaps and helps lock ball joints in place.. Only need a little and let it cure up before you reassemble everything
lotus7
1) Engine problems..
Nov 20, 2010 02:30 PM
rajaa11
Jul 10, 2006 03:02 AM
lightningcrazy
Apr 22, 2005 09:45 PM
98yamyz
May 20, 2004 10:38 PM
Warrior350ripper
Feb 12, 2004 02:31 PM
