Coolant pouring out of weep hole
Old Jul 6, 2015 | 06:46 PM
Coryco's Avatar
Default Coolant pouring out of weep hole
Hey OPT. As you know I rebuilt the engine on my 02 sportsman 700. was still getting coolant in the oil. So I had a Polaris dealer press in a new WP seal and oil seal. Put the cover back on with new gaskets put it all back together now I have a stream of coolant pissing out of the weep hole. Very frustrated. Is it possible to just plug the weephole and be done with it.
Old Jul 6, 2015 | 07:30 PM
Not really as the coolant is under pressure. All it will do is put pressure on the oil seal,plus if leaking past the water pump impeller and cavity,coolant flow will be leak and all it will do is run hot and possibly damage the engine. Sounds like if a dealer installed the new w/p seal and it's leaking,I'd take it right back to him and have him stand behind his work..
Alex G.
Sep 11, 2017 11:38 PM
Sassinm1
Sep 30, 2015 04:23 AM
2many2ride
Sep 27, 2015 04:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
