pvc spring spacer question
Old Jul 30, 2015 | 11:22 AM
chuck1177's Avatar
Default pvc spring spacer question
ok so im wanting to do the spring spacer mod and im wondering if i need to cut the coupler in half or what , the coupler is like 2.5 inches long and it seems like itll be to big !
Old Jul 30, 2015 | 02:15 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if your referring to my spring fix then no I didn't cut the spacer in half as they are not that tall if I remember correctly.
Old Jul 30, 2015 | 02:24 PM
chuck1177's Avatar
yea thats what im refering to , the coupler i got is 2 1/2 inches tall. also did you put pipe in both ends of the coupler ?
Old Jul 30, 2015 | 02:47 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes I put pipe in both sides and cut it off flush with spacer to give extra strength to the spacers. I will have to measure mine as I do not think I cut mine but maybe I did as it was 4 years ago. I have done this spacers fix to about 4 wheelers that has worked well for me.
Old Jul 30, 2015 | 02:53 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
well I just went and looked at mine and I was wrong as on my 500 I put grey spacers(electrical conduit)and cut them back to 1 1/4" high as I didn't want that much of a lift. on my 2 800's I went with white pvc sked 40 fittings and painted them. so I guess bottom line you can cut them to what height you want. sorry for the confusion.
Old Jul 30, 2015 | 02:55 PM
chuck1177's Avatar
ok yea ill do that ! thanks for ttaking time to check on that for me !!!
Old Jul 31, 2015 | 01:43 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you bet.
Old Aug 9, 2015 | 11:41 AM
chuck1177's Avatar
Ok so I got the spring spacers on and I also put a 2 inch lift kit on top of strut but now my tires are slanted inwards at bottom of tires ! It's pigeon toed bad , what's causing this or is it normal for it to be like this \ /
Old Aug 11, 2015 | 03:22 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
mine did that when I have too much of a spacer in it so I cut it down a little. toed in a little isn't bad but sounds like you have way too much.
ghost civic
Jan 15, 2020 07:43 AM
brinkkl2000
Oct 16, 2015 11:08 AM
Bergmann
Aug 13, 2015 03:51 PM
Wnthunting
Jul 9, 2015 03:02 PM
Mphillips
Jul 2, 2015 07:20 PM
