02 sportsman loosing charge
Old Aug 2, 2015 | 04:36 PM
Ronbo6270's Avatar
Default 02 sportsman loosing charge
HI.New to forum .my 02 sportsman 500 is draining my battery when riding but battery is new and holds charge when sitting. Starts up fine if I pull start it.any ideas? thanks for any information.
Old Aug 2, 2015 | 05:09 PM
First off pop the front panel off and see if any wires have pulled loose from the regulator. Common thing on many Sportsmans. If all are hooked up check what the voltage is at the battery slightly above an idle. If it just shows battery voltage or less usually the regulator is faulty.Plus it's been updated which usually means something. Item #35 on the parts break down. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Supposedly this one will work if you need one.http://www.ebay.com/itm/Rectifier-Regulator-FITS-POLARIS-ATV-4060173-2203636-NEW-/270668566659?hash=item3f051a9083&vxp=mtr
Old Aug 4, 2015 | 07:00 AM
Ronbo6270's Avatar
First off pop the front panel off and see if any wires have pulled loose from the regulator. Common thing on many Sportsmans. If all are hooked up check what the voltage is at the battery slightly above an idle. If it just shows battery voltage or less usually the regulator is faulty.Plus it's been updated which usually means something. Item #35 on the parts break down. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Supposedly this one will work if you need one.Rectifier Regulator Fits Polaris ATV 4060173 2203636 New | eBay
Thanks for info.
Old Aug 6, 2015 | 11:54 PM
MrMarty51's Avatar
Welcome to the forum Ron.
COFatboy
May 2, 2020 12:06 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Karas3434
Aug 3, 2015 09:17 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
