Changing Clutch on 2005 SP500 ?
Old Aug 12, 2015 | 12:55 PM
4464's Avatar
Default Changing Clutch on 2005 SP500 ?
Saw this on another thread with no replies but I am interested in it, figured someone here would chime in. Would a primary clutch from an '06 SP800 (geared lower?) fit onto a "05 SP500 with a clutch kit installed improve bottom end and mid-range?
Thanks!
Old Aug 12, 2015 | 02:15 PM
You can install an 800 clutch on a 500,but getting it to work right with a 500 rear clutch might be a different matter. To start of with what belt would you try to use? Both systems use different belts. Better off just keeping the clutches designed for it and installing a clutch kit for the 500. Have had people come into the shop that had mixed up clutches wanting me to get em to work right.All I could tell em was to get the right clutches for it.
Old Aug 12, 2015 | 08:46 PM
4464's Avatar
Thanks old polaris tech, I'm not looking for trouble so I will leave well enough alone.
Old Aug 13, 2015 | 12:30 PM
TLC's Avatar
TLC
It would be cheaper to just get a clutch kit installed if you want more bottom and mid then a entire clutch off of a different machine.
Epi Sport Utility Clutch Kit Polaris Sportsman 500 HO | eBay
Old Aug 21, 2015 | 01:46 AM
switzomatic's Avatar
I've had good luck with the EPI kits. QSC makes great kits as well. A big tire/mudder kit will give you more low end pull. Always use Polaris belts!!!
Cummins Driver
Sep 11, 2019 01:22 PM
txpedsrt1
Feb 3, 2017 08:07 PM
merryman
Jan 19, 2016 04:29 AM
tporath
Jul 11, 2015 12:31 PM
Shifts
Jul 3, 2015 07:59 AM
