New Shocks on Polaris 300
Old Aug 12, 2015 | 04:53 PM
Polarisman1123's Avatar
Default New Shocks on Polaris 300
Recently my shocks on the front of my 1994 Polaris 300 4x4 started leaking so i replaced them with brand new kimpex ones. I also did the cv boots while i was down there. I put the shocks back in, and pushed them right to the bottom of the strut and whenever i bounce on the front it feels like the shock is bottoming out. And it doesn't spring back up. Then when i tried to drive it, it would steer me left or right, after i backed up and then went forward again it would change from side to side and sometimes it would be fine. Seems like my 4x4 is kicking in for no reason just out of nowhere.
Old Aug 12, 2015 | 06:55 PM
Torque the hub nut to 12 foot pounds? Even if you did an armature plate on one side may be magnetized and allowing the hilliard to engage. Cheap as they are I'd pull the hubs and install new ones.Common for this to happen over time. Plus always use Demand Drive hub fluid.http://www.ebay.com/itm/New-Armature-Plate-for-Polaris-5211148-Sportsman-Scrambler-Magnum-1989-2009-/171549189657?hash=item27f120e619&vxp=mtr
Old Aug 12, 2015 | 07:48 PM
Torque the hub nut to 12 foot pounds? Even if you did an armature plate on one side may be magnetized and allowing the hilliard to engage. Cheap as they are I'd pull the hubs and install new ones.Common for this to happen over time. Plus always use Demand Drive hub fluid. New Armature Plate for Polaris 5211148 Sportsman Scrambler Magnum 1989 2009 | eBay
OK I'll try some new plates, but what about my shocks bottoming out? It feels like the shock hits the bottom of the cylinder.
Old Aug 13, 2015 | 08:13 AM
You can raise the cartridges up from the bottom of the strut a couple inches and see if it helps. If it doesn't help on bottoming out,then could be weak worn springs.
Bratman2
Aug 6, 2022 01:42 AM
Captjay
Jul 23, 2015 12:33 PM
1966F100
Jul 12, 2015 03:01 AM
cSchwartz
Jul 9, 2015 02:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
