Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
LT 80 Crank key / clutching
Old Aug 15, 2015 | 11:55 AM
gamer17's Avatar
Default LT 80 Crank key / clutching
My son's LT 80 clutching is screwed up. It's loud, and has a bog. Upon inspection I keep getting grooves on the movable drive face plate, starter gear and fixed drive face. I'm guessing the key is not keeping the movable drive face in place. I replaced all parts that were grooved and put it back together. After a quick test drive, same bog and all parts are starting to groove. Any suggestions?
Old Aug 15, 2015 | 12:38 PM
LT80's Avatar
LT80 Expert
Welcome to the forums.
It's a good guess that you are not aligning the key with the roller plate or it's slipping out of place, durring installation.
You must make sure that the lil key is in the roller plate notch.
Align the key/notch then hold the variator and stick the spacer in. It should stay in place BUT if it wiggles/moves, you must check again.
It's either that or the nut isn't tight.
FYI: the washer under the nut is a spring washer..Dome out.
Divergent12
Dec 30, 2017 08:33 PM
cdstang
Aug 31, 2015 07:52 AM
robert301972robert
Aug 30, 2015 11:34 AM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
clsharky
Jul 13, 2015 02:07 PM
