Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
Erratic spark on 05 Eton Viper 90R
Old Aug 21, 2015 | 06:52 PM
vinrum's Avatar
Default Erratic spark on 05 Eton Viper 90R
Hi, guys or gals. Newbie to the forum here. I have had this quad for my son for about a year now, the quad has ran perfect and all of a sudden, after 5-10 minutes of riding, the quad starts to bog and wont idle. The only way the quad will start back up is if I put the gear selector in (N) and shut the key off for a minute. Its almost like I have to reset the system. The quad had the carb cleaned, and a new plug, and a new battery. I brought it to a shop up the street from me, and he put a spark tester on the plug wire and took it for a ride.. The spark faded after 5 minutes or so, and it started running like crap again.. He shut it down and did the same as I mentioned above, and it started up no problem and it does the same after another couple of minutes.. He told me that its the CDI, but after reading some of the topics on this forum, I am not sure if I should spend the money.. And information is greatly appreciated..
Old Aug 21, 2015 | 06:58 PM
vinrum's Avatar
There is no tether switch on the quad
Old Aug 22, 2015 | 08:01 AM
LT80's Avatar
LT80 Expert
I'd lean toward the CDI also.
Better find out the tolerances and check the ohms.
Old Aug 22, 2015 | 02:47 PM
vinrum's Avatar
LT, where would I be able to find the tolerances? Also, what wires on the CDI would I be checking for Ohms?
Old Aug 23, 2015 | 03:52 PM
LT80's Avatar
LT80 Expert
Maybe you can find someone that sold etons or a manual.
There should be 2 wires that come from the motor.
One will be the charging side and the other the ignition side. You will check the ignition side.
Sorry, I don't know the exact colors for the wires or the ohm numbers.
Old Aug 24, 2015 | 06:06 PM
vinrum's Avatar
Thanks for your input LT.. I will have to try to do more homework
Old Aug 25, 2015 | 06:09 AM
vinrum's Avatar
Is LynnEdwards still on this forum? It looked from previous post that's the wiring Guru
Old Aug 25, 2015 | 09:40 AM
LT80's Avatar
LT80 Expert
Lynn works so much he can't come in much, if any.
Old Aug 25, 2015 | 09:46 AM
LT80's Avatar
LT80 Expert
I googled eton atv technical info.
Should be able to find whatever here.
http://get2itparts.com/etontech/SB0028.pdf
Old Aug 25, 2015 | 03:05 PM
vinrum's Avatar
Thanks a bunch LT!!! I will try giving that a shot.. I tried PM'ing Lynn but haven't heard anything back, hoping that he would read it, and shoot me his opinion..
