Winch issues
Old Aug 27, 2015 | 06:07 PM
Fubar008's Avatar
Default Winch issues
I have an 07 sportsman. The other night I got hung up and tried to use the winch. It worked fine all winter plowing but I hadn't used it this summer. I free spooled it to a tree then I went to pull myself out and out is in and in is out on the controls Once any tension is put on it just slips. it will pull the rope in but I can even stop it with my hand.
I don't know where to even start to look for the problem. Thanks
Old Aug 27, 2015 | 06:12 PM
1ArmBandit's Avatar
is the wire spinning on the winch spindle thingy or is it stopping the whole assembly
Old Aug 27, 2015 | 06:16 PM
Fubar008's Avatar
It's stopping the whole thing
Old Aug 27, 2015 | 06:19 PM
1ArmBandit's Avatar
hmm...just a guess but maybe has something to do with the free spool mechanism...the reverse in and out is weird too..hope its no toast
Old Aug 28, 2015 | 01:22 AM
switzomatic's Avatar
Might be possible it spooled all the way out and wound up backwards which would explain the control issue. As for the slipping, make sure the freespool **** is completely back to engaged. Sometimes they have a spring in there that goes too so it doesn't lock back in correctly...
Old Aug 28, 2015 | 07:31 AM
1ArmBandit's Avatar
Originally Posted by switzomatic
Might be possible it spooled all the way out and wound up backwards which would explain the control issue. ...
very possible, ive had this happen too
Old Aug 28, 2015 | 11:02 AM
Yooper265's Avatar
Only three possibilties - it was spooled all the way out and reversed on the drum as others said or the power wires to the winch got reversed or the control switch wires got reversed .
Old Sep 1, 2015 | 07:14 PM
Fubar008's Avatar
so turns out is did spool all the way out and reverse. one problem solved. it is still slipping. i messed with freespool **** but it seems like its fine.
toonces
Oct 19, 2015 02:21 AM
MNatv89
Aug 10, 2015 02:20 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
