polaris 2014 outlaw 50 wiring problem
Don't know if it has the same wiring as the earlier models,but should have a red,brown,black and green. If it's the same,the green should have power and goes to the tethered switch,from there should have power to the green/yellow wire at the left control start switch.If you're not jumping power from the switch could be the switch itself, switch harness connector or a wire may have broken loose from the solder from the back of the switch itself.We had problems with them doing that.
The ignition switch has 4 wires, 6" down from the switch it only uses 2 wires. I just used a jumper wire and it started and ran. I replaced the ign switch with a $5.00 toggle switch, it works fine.
thanks nick c
thanks nick c
