Hello all :) I need help with a Trail Boss 325 2X4 ATV
Old Sep 6, 2015 | 07:48 AM
oliveiracarlos's Avatar
Default Hello all :) I need help with a Trail Boss 325 2X4 ATV
Hello,
I´ve recently acquired a Trail Boss 325 2X4 ATV, I hope I can get some help with you guys to keep my four wheel bike OK
By the way I´m from Portugal, sorry for my English.
Regards,
Carlos Oliveira
Old Sep 7, 2015 | 01:22 PM
Can anyone help me with the following:
1 - I recently bleed my brakes and now the lever is two hard, just a little touch and is already braking, is this normal?
2 - I also have a problem in the foot brake, it get´s no pressure and does not brake, what can cause this?
3 - Is it normal that the hand brake brakes more in the front that in that back wheels?
Thanks
Old Sep 8, 2015 | 04:43 AM
What's the problem?
Old Sep 8, 2015 | 06:47 AM
I have the following doubts:
Old Sep 8, 2015 | 08:38 AM
scootergptx's Avatar
Supersock
Hired Gun!
The hand brake works both back and front brakes. That is why there are two bleeder screws on the rear caliper. The brake pedals are known to be weak on these and a few other models.
As for the front being too hard, I never had that problem with mine after bleeding.
Old Sep 8, 2015 | 08:59 AM
The problem is that the foot brake does not brake at all, i will try to clean the back caliper, it can be stuck due to the fact that the bike was stopped for about a year.
Another thing i will do is the bleeding in the front brakes, i forgot them.
Old Sep 8, 2015 | 09:04 AM
Hello Old Polaris Tech,
The problems i have are:
I bleed my brakes and now the front brake lever is too hard, just a little touch and already brakes. But without braking the bike is completely loose.
The foot brake does not brake at all.
Is it normal for the hand brake to brake harder in the front than in the back wheels?
Sorry for my English and thanks for the help
Old Sep 8, 2015 | 09:05 AM
Old Sep 8, 2015 | 10:26 AM
Rear hydraulic brakes are the weak point on Polaris atvs because the master cylinder is so small. Common problem on all the later models.The small rear master cylinder seals also leak after several years and you either have to replace this expensive part or you can rebuild them now that seal kits are available. If you have access to a vacuum bleeder such as a Mityvac,it makes bleeding a lot easier also.http://www.ebay.com/itm/POLARIS-TRAIL-BOSS-REAR-BRAKE-MASTER-CYLINDER-SEAL-REPAIR-KIT-DR16-/271954333239?hash=item3f51bdce37&vxp=mtr
Old Sep 8, 2015 | 05:29 PM
Thanks for the help, during the weekend i will disassemble it and check if the cylinder are working ok, if not i will rebuild it. I´m counting with your help if i have some doubts during rebuild
Has to bleed i don´t have the vacuum bleeder, what i do is using the same method i use in my mountain bike. I use a syringe and inject the oil from the bleeder point to the master cylinder in the brake handle.
