Fan wont shut off
Old Sep 28, 2015 | 04:03 PM
Gwolf228's Avatar
Default Fan wont shut off
Hello I have a 2000 polaris 325 magnum changed out the voltage regulator and put in a new battery have no problems with it starting,,it's just that the fan runs constantly even when you turn the key any suggestions,,,
Old Sep 28, 2015 | 04:42 PM
A lot of times the thermister sensor on the oil cooler can short out and cause the fan to run constantly. It completes the ground path through the thermister module for the fan to kick on. You can ohm out the sensor. Should show some resistance when cold,resistance drops as it gets warmer.If it zeros out on the meter when cold,likely it's the problem. Also the module itself can short out internally and basically do the same thing. Some people ended up having to replace both which is expensive. The manual has the specs on checking this system out. Might be best to have it before you do anything. Here's one for 10 bucks.http://visit.tradebit.com/visit.php/...75/264163829/9 The thermister module is right next to the regulator you replaced. Like I mentioned these parts are high dollar. Here's the sensor from ebay.
http://www.ebay.com/itm/Polaris-4010274-THERMISTER-/271997517969?hash=item3f5450c091&vxp=mtrPlus here's the module listed at Cycle Parts Warehouse. Item #32.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
One other option that some have done is to run a toggle on the fan hot wire and kick it on when under loads or slow operation. PLUS these fans rarely ever kicked on to begin with unless super hot. A lot of other machines are air and oil cooled and don't have fans.Toggle switching the fan is one option that I would highly consider if this 15 year old machine was mine.
Old Feb 17, 2017 | 10:46 PM
Mattt650brute's Avatar
Default How do I start a thread? Sorry about randomly posting here
hi, how do I start a thread sorry for just randomly posting here about the only think I know how to do thanks in advance
Old Feb 18, 2017 | 01:36 AM
user493's Avatar
Moto Psycho
If it's a problem with a Polaris go to either the regular Polaris page or the ask an expert page. There's a button near the top on the left side that says "new thread". Click on that to start a new thread. All the other sections of the forum work the same way.
lonerider856
Oct 13, 2023 03:45 PM
Customer Service #1
May 15, 2020 08:46 AM
mrtidy
Feb 3, 2016 05:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
Matt123
Sep 29, 2015 01:29 AM
