Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
how to adjust valves on a yamaha moto 4 80
Old Oct 3, 2015 | 06:44 PM
Carlosliquor's Avatar
Default how to adjust valves on a yamaha moto 4 80
just wanting to know where i can find instructions or a video on how to adjust the valves and the settings
Old Oct 6, 2015 | 03:00 AM
I was hoping someone else would write in as I have only done this on later Yam 80s, and it was a long time ago. However I recon yours will be the same. Remove the screw in caps over the valves. Turn the engine onto top dead centre on the compression stroke, there is a recent posting in the Yam section about doing this on a Warrior. Check the inlet valve clearance, I'm not certain but I think it was 0.003", if it is out, slacken the locknut on this rocker arm, turn the adjuster, (anti-clockwise to increase clearance), tighten the locknut when the clearance is 0.003" and repeat for the exhaust valve. Re-fit the covers.
Old Oct 6, 2015 | 06:54 AM
Default Thanks
Thank you, however I have found an online manual for the 4 wheeler. The steps you mentioned were correct. It purrs like a kitty. Starts on first try.
buddieboy
Dec 9, 2016 05:50 PM
Zehno
Sport Quads
Jan 2, 2016 01:31 PM
blp
Oct 2, 2015 03:38 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
lgardner61980
Sep 20, 2015 01:32 PM
