engine light code 41 46
Old Oct 10, 2015 | 07:02 AM
stcspiderman's Avatar
Default engine light code 41 46
What is causing 41 46 code where do i start try figure the problem out
Old Oct 10, 2015 | 09:02 AM
Would help to know what model and year of the machine.. Are their any symptoms such as hard starting,backfiring,erratic idle or are the codes popping up but running ok? Codes 41,46 are usually associated with tbap or map sensor harness problems on the 700 and 500 efi models. Usually not a sensor problem in itself. Look at this site that has harness repair kits and codes that usually thrown if you're having problems.Only The Best
Old Oct 10, 2015 | 10:37 AM
Sorry thought put in there 2007 sportsman 800 efi starts fine no backfire
Old Oct 10, 2015 | 10:58 AM
Disconnect the battery,wait 30 seconds and hook back up and see if code clears. You can also check the tbap harness for any wear or bare spots or soft feeling wires indicating a problem that would throw the code. Even though you may not be having symptoms now, if code comes back it could be a good enough warning to replace with the repair kit(harness and connector) offered by OTB.
Old Oct 10, 2015 | 01:05 PM
Where istbap harness located
Old Oct 10, 2015 | 01:47 PM
On the air tube leading to the air box. Item#12.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Check the wiring for any bare or soft spots all the way until they merge into the main harness. Plus wires can slightly pull out of connectors going into the sensor. Sometimes hard to trace down. Polaris repair kits were junk,I replaced them over and over again.Kits from otb are stronger with better connectors and wiring. You can remove the sensor from the air duct an gently clean the tip with a soft cloth and replace it. May or may not help on throwing codes if the harness is the problem..
Old Oct 10, 2015 | 03:11 PM
Might be the issue no idea how this happened
Where do i get new connector
Old Oct 10, 2015 | 03:12 PM
<a href="http://s245.photobucket.com/user/stcspiderman/media/20151010_140051_zpsn4iwzdk0.jpg.html" target="_blank"><img src="http://i245.photobucket.com/albums/gg59/stcspiderman/20151010_140051_zpsn4iwzdk0.jpg" border="0" alt=" photo 20151010_140051_zpsn4iwzdk0.jpg"/></a>
Old Oct 10, 2015 | 03:33 PM
From otb that I mentioned in my first post! Typical Polaris connectors,JUNK.. Comes with connector,wiring,and shrink connectors I believe. Only The Best
m2cyclone
Jan 6, 2021 06:24 PM
doccod7
Nov 24, 2016 08:38 AM
LaneWebster
Oct 14, 2015 06:56 AM
TheATVSuperStore
Oct 6, 2015 03:51 PM
Goob's Repair
Oct 4, 2015 01:05 PM
