2003 Polaris 700 "StAtr"
Old Oct 12, 2015 | 02:52 PM
J1985's Avatar
Default 2003 Polaris 700 "StAtr"
Hey I am new to the forum!
I was driving my 03 sportsman 700 and noticed "StAtr" flashing on the screen. I have read in the forums that it could be stator or ground issues? I checked grounds at the front under the panel everything seems ok and tight, I have 14volts while idling. The bike starts and runs fine just flashes this code. I just purchased it about a month ago and it looks like it has the original ignition system. any other things that i can check before i replace with the upgrade kit?
thanks in advance.
Old Oct 12, 2015 | 04:20 PM
You've checked enough. Replace with the Kokusan ignition upgrade kit #2202602 Here's a good video that shows the problem on hidden wires that the instructions don't show when hooking the new kit up.
Old Oct 14, 2015 | 02:05 PM
Big600twin's Avatar
Unfortunately the best solution is to do the replacement. It may intermittently run OK and then it will just not start....Yes I speak from experience.
Good Luck.
Old Oct 14, 2015 | 02:07 PM
Big600twin's Avatar
I forgot to mention...Welcome to the forum. You will find great resources her,e especially from OPT!!
Stirling
Aug 9, 2015 01:49 PM
Sportsman850
Jul 31, 2015 04:25 PM
binky79
Jul 30, 2015 06:37 PM
anad86.
Jul 28, 2015 04:57 PM
Schneider
Jul 24, 2015 05:05 PM
