Carb problems
Old Oct 27, 2015 | 07:04 PM
Buckshot1's Avatar
Default Carb problems
New to the sight I'm trying to fix a buddies polaris 425 2×4 magnum 1995 this 4wheeler has sat for a few years but ran fine when parked cleaned the tank and lines fuel pump got to the carb torn down soaked for a couple of days cleaned all parts with carb cleaner and used a air hose to dry put carb back together motor starts right up but boogs down as I apply throttle I've been back into the carb a few more times with the same result if anyone can point me in the right direction would be much appreciated
Old Oct 27, 2015 | 07:12 PM
Do you have the air box and filter back on? If not they wont take throttle unless you do.
Old Oct 27, 2015 | 07:51 PM
Buckshot1's Avatar
I do indeed its all back together and complete
Old Oct 27, 2015 | 08:03 PM
If you still have the foam support collar make sure it's not blocking air flow. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Plus you can make sure it's getting enough fuel by pulling the line from the carb and cranking the engine over. Should have a steady pulse of fuel from the pump. Not a fan of just cleaning carbs as that doesn't always help. Carb kits or at least a new needle and seat especially on a machine that's been sitting up for years.NEW SHINDY CARBURETOR CARB REBUILD/REPAIR KIT FOR POLARIS 425 MAGNUM 1995-98 Float level needs to be set correctly also.See if this pdf section from the manual helps on the carb and float level setting.You have the BST34 carb.https://www.google.com/url?sa=t&rct=...U2gGlaHJWSIlbA Might not be abad idea on checking valve clearance(.006 intake and exhaust) and checking the exhaust cam lobe for wear. This was one of the models affected by soft heat treatment on cams. I saw that it was supposed to be running good when it was put up for 2 years,but I've heard that before also.. Just the old negative mechanic in me I guess
Old Oct 27, 2015 | 08:10 PM
Buckshot1's Avatar
No foam on filter and I'll check the fuel line I just got off line ordered a new fuel pump and carb kit I'll keep in touch let ya know this all works out
Thank you
Apr 23, 2017 07:42 PM
rawbdiggity
34
Sep 2, 2015 02:16 AM
WesTech
11
Aug 11, 2015 07:55 AM
binky79
Jul 30, 2015 06:37 PM
