fuel guage stuck on full
Old Nov 1, 2015 | 11:32 AM
DOC HOLIDAY's Avatar
Question fuel guage stuck on full
hello,my 2007 polaris 500 x2 has a stuck fuel guage,it worked fine until i filled up the tank.now it will not move off of full,it has the 500,with efi,any ideas,thanks
Old Nov 1, 2015 | 11:51 AM
Can't remember if this model had the wire arm with the float or the slider float in the pump. Either way sounds like the float may be may be stuck against the side of the tank(if it's the wire arm model) or a wiring problem if the float's in the pump assy. If this used one for sale is for the correct year model,then I'd bet the float arm needs to be bent out a tad and it should go back to working ok.#567 2007 Polaris Sportsman 500 4x4 fuel pump assembly
m2cyclone
Jan 6, 2021 06:24 PM
Matthew James
Oct 19, 2015 11:43 AM
stcspiderman
Oct 11, 2015 11:17 PM
Old Deer Hunter
Oct 11, 2015 02:43 PM
mpcwizzard
Oct 5, 2015 08:53 AM
