Tire size change for 300ex
Old Apr 10, 2001 | 09:32 PM
atvdad37's Avatar
Q;stock 22-10-9 want to go with 20-11-9,What changes do i need?I heard i need to change front sprocket to 12tooth(stock 13).also looking for advise on rear tires razrs or bandits.I ride mud and about every thing.
Old Apr 11, 2001 | 03:08 PM
ex_master's Avatar
No if you go to 20" tires with 12t front you will have too much low end, if your looking for more lowend you should stick with the 13t tires because you will end up with more lowend. If you want to stay near stock power go with a 14t.
Old Apr 11, 2001 | 03:20 PM
YZGUY's Avatar
I ran 20" Holeshots on the 300 for a while. It made the rear lower, and I was hitting a LOT of rocks. So, I went back to 22" (Holeshot XCT's). If clearance is a problem, that's something you will want to consider. An extra inch of clearance makes a lot of difference when you're only 4" off the ground. Consider rim width too when changing tires. A narrow rim will give you a taller and rounder tire profile than a wide one. Ex_master is right, you would go up a tooth in front to maintain stock gearing with 20".
Bratman2
Aug 6, 2022 01:42 AM
Schneider
Jul 24, 2015 05:05 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
