4x4 icon on dash not lighting up
Old Nov 5, 2015 | 10:39 PM
thatguy87's Avatar
Default 4x4 icon on dash not lighting up
Went riding last weekend and noticed that the 4x4 icon wasn't on when I was in 4wd(4wd does work)....the icon does work because when I turn the atv ignition on it lights up...what would cause this... smh
2006 polaris magnum 330 4x4
Old Nov 6, 2015 | 07:28 AM
Pull the speedo connector and grease it with electrical grease,plus do the same for the gear selector switch on the tranny. May be as simple as getting an intermittent signal to the speedo.
Old Nov 6, 2015 | 12:29 PM
thatguy87's Avatar
Can anyone tell me what the white 3 prong plug under the front lid with all of the other wires is? It just looks out of place.
Old Nov 6, 2015 | 12:33 PM
thatguy87's Avatar
Old polaris tech, I just greased them up and still no light. Also how do you check the front differential fluid and how do you add fluid?? My polaris dealer always did it for me
Old Nov 6, 2015 | 04:12 PM
The plug is just a test plug that they hooked up to on the assembly line to test the electronics. Just tuck it up back out of the way. Your best bet on tracking down the problem is to have the wiring schematic and trouble shooting guide that the manual has.Better than going at it blindly. Worth the 5 bucks for this problem,future problems and service related items such as fluids needed and capacities. 2006 Polaris Magnum 330 Service Manual PDF Download
Old Nov 7, 2015 | 03:09 PM
thatguy87's Avatar
So I brought I atv to the dealer today just for them to take a quick peak cause they didn't understand over the phone what I was talking about...they told me they didnt know why it was doing that either..they told me as long as fwd engages you should be fine...oh well guess I'm fine than..
Old Nov 9, 2015 | 03:52 AM
thatguy87's Avatar
Went to take it for a rip yesterday....the 4wd icon was lit up...lol
Old Nov 9, 2015 | 08:36 AM
Check the pins in the speedo connector. All it takes is for one pin to push back a little for it to have an intermittent contact.Or a pinched wire can do the same thing.
Jazperman
Aug 7, 2016 08:12 PM
Sep 9, 2015 06:57 AM
rawbdiggity
34
Sep 2, 2015 02:16 AM
snowolson
Aug 31, 2015 03:51 PM
mattcraig1
12
Aug 27, 2015 12:23 PM
