21cc on stock pistons
Old Nov 16, 2015 | 10:07 AM
M1794's Avatar
Default 21cc on stock pistons
Hi guys,I'm going to order a cool head for my 08 banshee (stock) I was just wondering should I go for 20cc domes or 21cc domes ? Any ideas?, is it safe? ... thanks in advance.
Old Nov 16, 2015 | 01:27 PM
Scooter86's Avatar
Knows Old ATV Questions!
The larger domes are going to be a safer bet to run pump gas. Not a lot of Banshee guys around here anymore unfortunately. I would try contacting the head manufacturer, or if your engine has been ported/stroked your builder may be able to help. In the end, you just may need to perform a good old fashioned squish test to make sure you are in the right compression range for your desired octane rating. I know some of the 250r forums are good resources to find the squish test procedure. Good luck!
Old Nov 16, 2015 | 01:30 PM
Scooter86's Avatar
Oh, and we're do you live that you are lucky enough to have an 08? I'm a little jealous, lol.
Old Nov 17, 2015 | 08:47 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
I would go with the 20cc's. I have 17's in mine and I need to run race fuel. I had my stock head milled .010 on my other one and can run super in it. My 4 mil has 180 psi cold compression and the other has 150. 165 and up is where you need race fuel and 145 and up for super. Check compression after you install them to see what fuel to run.
Canwoodsman
Nov 20, 2015 04:07 PM
EdgarAdams
Nov 15, 2015 06:13 AM
