96 xplorer 400L 2 stroke
2,800 miles
Father in laws rig. He said it has been over heating (light came on). I know it has had a small coolant leak for a while, appears to be coming from the left side but I haven't confirmed that.
I can see through the radiator fins, doesn't look clogged. This atv doesn't see mud or rough riding.
I bypassed the thermal switch and the fan came on but it sounded like rocks for bearings. My question is can the bearings be replaced on these motors?
Now I'm not sure if the thermal switch isn't working or if the other two problems are creating the overheating??
Usually the sensor at the top of the radiator shorts out if coolant falls below it not allowing the fan kick on.. If it's leaking coolant fix this problem first. See if you can match this sensor up at an auto supply. Item #8. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Too expensive here and on ebay.Thermal Fan Switch Assembly 1996 Polaris Sportsman Xpress Magnum 300 400 500 | eBay
Plus no the bearings are sealed in the fan motor. Motors aren't cheap for these either.New Cooling Fan Motor Polaris Xplorer Explorer Xpress Express 300 400 500 ATV | eBay Plus don't know if you have enough room around the back of the radiator to use an all in one unit or not like this or a way to mount one up properly.. Automotive Electric Fan 11 1 2 x 12 1 2 Universal Electric Fan Made in USA | eBay
polarisrider1203
Aug 29, 2015 07:52 PM
