Sportsman 500ho motor chiped cam lobe?
Old Dec 23, 2015 | 06:29 AM
Ipmcelroy's Avatar
Default Sportsman 500ho motor chiped cam lobe?
So i recently picked up a 2001 sportman 500 h.0. Complete running engine for only $200 bucks. I wanted to check things out with it so i pulled the valve cover and rockers out. The pads on the rocker arms are not worn only where the de-compression ball hits. On the cam i did notice that one the intake loabs it looks like each one was chipped possibly on the sides but each one looks identically as far as a possible missing pc. Of loab. As i look closer it kind of looks like it was made that way? Have these cams been known to chip or more so just ware down. I find it hard to beleive that each loab would chip the same on each intake loab the exact way and spot.
Old Dec 23, 2015 | 06:36 AM
Probably just milled that way.. As long as the rocker pads are good,no worn spots,wouldn't worry about it as intake lobes are rarely ever a problem.
Old Dec 23, 2015 | 06:43 AM
Ipmcelroy's Avatar
Great thats kind of what i was wondering. I may used the cam and put it in my 1997 non ho sportsman as i have an extra ho carb kicking around. Its a pretty noticible difference in power low end between my 09ho and 97 non!
Old Dec 23, 2015 | 10:00 AM
TLC's Avatar
TLC
You can use the NON-HO 34mm carb with the high duration HO cam if you want.
shore
Dec 19, 2015 09:17 AM
TRXWOLV
Dec 8, 2015 03:08 PM
Jim MgGinn
Dec 4, 2015 01:01 AM
