2001 Scrambler Pull Start Bolt Size
Old Dec 25, 2015 | 05:30 PM
Bosgarage57@aol.com's Avatar
Default 2001 Scrambler Pull Start Bolt Size
Hi guys, I have an 01 scrambler 4x2 500. Replacing the pull start and.....all the pull start stuff is not there! go figure. Before I order the pull start stuff I'd like to see if the bolt that goes in the case for it, if the threads are stripped. Does anyone know the size of the bolt that it uses?
Also, my rear brake bleeders are broken off. Is $27 each the cheapest I'll be able to find?
Old Dec 25, 2015 | 07:59 PM
The recoil bolts are 6mm x 1.0 pitch. You can either replace the guts like this kit has.Recoil Starter Pull Start Kit Polaris Sportsman 500 ATV 1996 2011 Brand New | eBay Or there are complete aftermarket recoils and bolts that are reasonable.Polaris Complete Recoil Starter Pull Start Assembly Sportsman 500 1996 2011 | eBay
The bleed screws aren't cheap,but a little cheaper here.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse One thing you can do when you remove the broken bleeders you can try to match the thread pitch up at a good auto supply.May be able to save you some money.
JCDEYO25
Dec 19, 2015 06:10 PM
Robert1980
Dec 12, 2015 08:27 AM
Robert1980
Dec 8, 2015 12:53 PM
Garfoot
2) Chassis problems..
Dec 5, 2015 12:43 PM
