98 sportsman rear caliper rebuild?
Old Dec 28, 2015 | 10:40 AM
Ipmcelroy's Avatar
Default 98 sportsman rear caliper rebuild?
Trying to get the caliper pistons out of caliper housing. One will go out while pumping brakes, the other one got pushed in to far flush with housing and will not pump out. Any ideas how to pull it out or push out . I would like to rebuild them w new seals.
Old Dec 28, 2015 | 10:49 AM
Place it on a work bench,have a towel around it and use a blast of compressed air through the bleeder.It'll come out. Just be carefull.
Old Dec 28, 2015 | 10:51 AM
Ipmcelroy's Avatar
Will try thx. Rather not do the greese trick!!
Old Dec 28, 2015 | 04:36 PM
Ipmcelroy's Avatar
I tried the compressed air it did push one side out . the other side i did have to pump out with a grease gun. If anyone needs to know a grease fitting screws perfectly into either brake bleeder just remove the nipple and screw in the fitting. You do have to find a couple fine thread bolts to plug the brakeline inlets. My caliper i found had a peice of the seal chunked off.
Prorguy
Feb 18, 2016 05:46 PM
Ipmcelroy
Dec 28, 2015 10:23 AM
Matthew30
Dec 27, 2015 04:22 PM
Bosgarage57@aol.com
Dec 25, 2015 07:59 PM
JCDEYO25
Dec 19, 2015 06:10 PM
