What Did I Do Wrong?
Old Jan 1, 2016 | 08:19 AM
jeffreybandel's Avatar
Default What Did I Do Wrong?
2001 Polaris Sportsman 500 HO.
I was having major no starting issues. I replaced the Stator, Bendix and Recoil Assembly. The good news is it starts and runs fine. The problem now is it doesn't drive. I can have it in gear and driving but then it comes to a stop even with RPMS up. What did I do?
Old Jan 1, 2016 | 10:32 AM
Sounds like you burnt a belt or have clutch problems or a little of both. Just pull the clutch cover and go from there.
Old Jan 1, 2016 | 12:54 PM
OK. Thanks. Sounds like more fun.
Old Jan 1, 2016 | 01:17 PM
Machine new to you?
Old Jan 1, 2016 | 01:28 PM
No. I've been fixing it for years...
Old Jan 1, 2016 | 01:38 PM
Sorry couldn't help it..
Look at these post as the 2000 through 2002 were the worst on clutches if the belt isn't the only problem.http://api.viglink.com/api/click?for...st%20Community
Old Jan 1, 2016 | 03:29 PM
I got the cover off. About 2 cups of black fluid came out. What should I be looking for?
Old Jan 1, 2016 | 03:32 PM
Here it is.
Old Jan 1, 2016 | 04:01 PM
Usually item#22 is the culprit or even the outer clutch seal #10. Have to pull the clutch to get to this seal. Usually sticks can puncture this engine to clutch seal and allows a lot of water to mix with clutch dust.. Sounds like the cause of you slipping,hopefully.. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
http://www.ebay.com/itm/5412637-Pola...NV~hZO&vxp=mtr
Old Jan 2, 2016 | 05:47 AM
Before I take it down I was wondering if I can see the clutch slipping with it in gear and running?
