split rims
Old Jan 2, 2016 | 07:41 PM
wamulass's Avatar
Default split rims
Does anyone know where i can find single piece wheels for my little honda 110? The split rims are giving me fits and the only way I can mount them is if i tube them. Tubes in tires are hard to deal with if you get a flat so I am trying to switch to one piece rims.
Old Jan 3, 2016 | 11:31 AM
Hated those split rims when they came into the shop. Each side has has to scraped down and clean and the o ring has to be in good shape or you're just wasting time. Found one place that may or may not be able to help.ATC70_ATC90 POLISHED ALLOY_WHEELS DOUGLAS_8"X8" 3_ON_100mm BOLT_PATTERN (4"/4"_OFFSET) (SOLD_EACH) exed sorry discontinued Plus read a three wheeler forum to where one member said this.."You can get rims for the 81 250r that are aluminum 3/100 .This rim should also fit the 110." Don't know if he's right or wrong on this...
Old Jan 10, 2016 | 06:04 PM
mmumm's Avatar
If your wheels are leaking between where they meet, I had the same problem. I let air all out, loosened the bolts, and put silicone between the two, and tightened back together. Hasn't leaked any air at all and it was easy to do.
merryman
Apr 26, 2016 04:39 PM
twin051302
Jan 2, 2016 04:47 PM
panicmanic
Jan 1, 2016 01:07 PM
Rincon06
Dec 29, 2015 02:22 PM
