Scrambler 50 throttle problem
Old Jan 7, 2016 | 11:43 AM
Berka81's Avatar
Default Scrambler 50 throttle problem
I bought this for my kids.
as soon as you hit the throttle (no matter how far the stop screw is in ) it pretty much goes full speed. I can't figure it out? . It's just so hard to teach a kid to ride when the quad only goes one speed which is to fast. any help would greatly be appreciated.
Old Jan 7, 2016 | 02:52 PM
Sounds like you need to check the throttle cable for binding or in the carb itself for throttle slide sticking.
Old Jan 7, 2016 | 03:25 PM
Berka81's Avatar
thanks for your reply. Do you think the problem is in the carburetor ? I can not much about this particular atv but had my suspicions about the cdi box . I must have a scrambler of model year 01 or 02 because there are no connections for the jumper cable. dare to buy a new carburetor on ebay for example??
Old Jan 7, 2016 | 03:32 PM
Sounds like what a cable or carb could do. You may not have to get a new carb,but if needed plenty of people have bought the cheap Chinese knock off carbs on ebay. Just check that jetting is the same or swap out the main and pilot jet from your carb. Plus in some cases if a crank seal was leaking engines could rev up,but if it at least idles ok,wouldn't think it would be a seal problem.Carburetor ATV Polaris Scrambler Carburetor 50cc 90cc 2 Stroke Carburetor Carb | eBay
Old Jan 7, 2016 | 03:39 PM
Berka81's Avatar
Love quick and competent answers . thanks so much! do you mean that I would dare to buy carburetor you link to ?
Old Jan 7, 2016 | 03:44 PM
Only if a carb is really needed and you'd rather not spend $325 bucks for a new Mikuni carb,even at discounted prices here. Item#16.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Jan 7, 2016 | 04:00 PM
Berka81's Avatar
Carb is perhaps not my strongest side , but I 'll have to teach me. What should I consider when I pick it away from engine and what should I look for when have dismantled it? Again , many thanks for your quick response
Old Jan 7, 2016 | 04:29 PM
Couple videos on you tube that can help.
Plus here's a generic video on small two stroke carb adjustments.
Old Jan 8, 2016 | 01:26 AM
Berka81's Avatar
Have ordered a Chinese carburetor from ebay now. not so hard when it only cost 20 dollars. thinking of spending Saturday in the garage to disassemble the carburetor and see if I can find anything abnormal . currently it is -16 degrees outside here so children stay indoors anyway .
Old Jan 8, 2016 | 01:32 AM
So would I at those temperatures..
