570 park disable !
Old Jan 11, 2016 | 07:47 AM
bartlettracing's Avatar
Default 570 park disable !
So I got a new 570 and started plowing with it, First thing that bothered me was I cant find reverse ! my old quad I had to press the brake to goto park. This one you don't. so you end up wiggling the dang shifter back and forth getting into reverse... pain in the ****. Took the thing apart and made a bracket to block park. Wow I love it ! just pull it back and take off ! Very simple to make and very simple to remove after plow season or any other reason you would want to remove it .. Imo I dont need park. I can just lock the brake if need be .. 99% of the time its sitting on flat ground any way.
Size:  42.0 KBName:  12494884_10153880739921468_5242632766822374334_n_zps9y0hrnkd.jpg
Old Jan 11, 2016 | 04:31 PM
WilliamBos's Avatar
If you are not going to use park, use neutral. You can hourglass a belt pretty fast if you let it sit idling in gear.
Cool mod, thanks for sharing.
fhorta
Dec 17, 2015 07:53 AM
adge_denkers
1) Engine problems..
Nov 29, 2015 01:36 PM
Timbo2500
Nov 15, 2015 09:02 AM
hkc3
Nov 7, 2015 04:40 PM
trouttracker
Oct 19, 2015 08:05 AM
