Help Honda Owners
Old Jan 16, 2016 | 08:15 PM
yooper66's Avatar
Default Help Honda Owners
I own a Honda Trx 420 Rancher 4x4 Fi
I Replaced Brake Pads, Fluid and I Still dont have any Brakes! Zero Resistance on the Levers. Any Ideas?
Old Jan 17, 2016 | 02:12 AM
Have you tried to bleed the brakes? If you have,but still no firm master cylinder,a mityvac brake bleeder can make short work of bleeding brakes. Plus not sure how your system is set up,but if you can clamp off the hose close to the master cylinder with vice grips,it helps to at least get the master cylinder primed up first. Then bleeding may go easier.
Old Jan 17, 2016 | 09:24 AM
yooper66's Avatar
Thank You Tech, I believe the answer is in Priming the Master Cylinder.
merryman
Apr 26, 2016 04:39 PM
GamMattic
Feb 2, 2016 11:00 PM
hoowahfun
Jan 13, 2016 08:21 AM
mmumm
Dec 25, 2015 10:13 AM
