Painting or wrapping exhaust
Old Jan 20, 2016 | 09:59 PM
SWFLMUD's Avatar
Default Painting or wrapping exhaust
Had to have my pipe welded where it goes from double to a single pipe on my 06 800. Now that it's off I'm wondering if painting it with a high temp paint or wrapping it with the black pipe wrap, or possibly even both would help. Hoping to reduce the heat from under my leg since I ride in shorts mostly. I hate wearing pants, and the heat had ruined 2 sets of waders.
Thanks, always appreciate the input.
Old Jan 21, 2016 | 12:23 AM
switzomatic's Avatar
Wrapping should help. Could also try making a heat shield.
Old Jan 21, 2016 | 06:41 AM
JCDEYO25's Avatar
I've heard that if you're in water alot and it appears you do some muddin, that the wrap holds moisture from being wet all the time and in time rots the exhaust..If you have the whole exhaust off maybe consider having it ceramic coated like Jet Hot to keep the heat down. Not cheap but my buddy had it done years ago on his and was pretty impressed...
John
Old Jan 21, 2016 | 08:09 AM
Diverod's Avatar
I wrapped mine but I wouldn't have if was doing much in mud/water. The wrap did the most for sound damping. I guess it may have reduced the heat some, but to me it still gets very hot. If you could figure out a heat shield that may work best.
Old Jan 21, 2016 | 08:34 AM
If the exhaust on the 800s are glowing red,they can be reflashed to try to help this. We had to do this on quite a few 800s that were running too lean and people would complain about the heat or get their legs burnt.
Old Jan 22, 2016 | 08:52 PM
Uberbricky's Avatar
If you're getting DEI exhaust paint I'd wrap it after too. If you go with a ceramic coating you won't need the wrap, but could always do a section where your leg is.
I'm painting mine at home and wrapping it with the lava wrap. Done it before on car headers, worked like a charm.
Old Jan 22, 2016 | 11:48 PM
1ArmBandit's Avatar
mud with it go swimming with a wrap lol..with the temps youre trying to subdue, the wrap and anything on the exhaust will be dry in minutes id bet
bthrel
Jan 27, 2016 08:07 AM
stangman347
Jan 19, 2016 02:59 AM
ATVAdventurer
Where to Ride
Jan 10, 2016 02:00 PM
Clapper66
Dec 27, 2015 06:49 AM
