Clutch thoughts 550xp
Old Jan 25, 2016 | 11:06 AM
SOLOLUCKY's Avatar
Default Clutch thoughts 550xp
I am having some thoughts on clutching my 550xp.
A kit is in excess of $200 and some are over 300...It has 28" Zillas on it. came stock with 26" tires. I am sure it could use a bit of clutch work but it does well without an clutch mods but the stickier mud definitely clings up the tires and holds them back when in the deep stuff (shich i don't do very often, only occassionally) . anyway, would a simple spring mod do anything to help it out ? something cheaper and a bit easier since it is mostly a trail ridden machine and it seems to do ok in every way except the worst conditions.
I guess i really do not fully understand how the 2 clutches work.
We just installed a QSC clutch on my boys 400ho and i could tell the springs for both clutches are stiffer than the stock ones. also the weights were maybe heavier but we didnt weigh them.
so without a weight change, only a spring mod would that help me out ?
Also i investigated QSC for mine and the 2010 requires a helix change and the company that made them for QSC is no longer in business
Old Jan 25, 2016 | 11:40 AM
Since a Qsc clutch isn't an option now,what about a simple kit from Epi. Products - ATV / UTV - Clutch Kits - Polaris - 550 - Sportsman - EPI Front clutches senses torque/power from the engine,rear clutch senses speed and transmits this to the gear case. That's the practicality about cvt clutches. You're in the right "gear" range at the right rpms at all times.
Old Jan 25, 2016 | 01:08 PM
SOLOLUCKY's Avatar
So , on the most basic level, the stiffer the spring the slower the clutches react.
what does the weights do ? when they spin they "drive open" the front clutch overcoming the spring pressure ?
Old Jan 25, 2016 | 01:30 PM
See if this can explain better than I can.
Same principal as a 10 speed bike also. As you start out you have a small front sprocket and larger rear for take off power. As you go through the gears,the front gear becomes larger,the rear smaller for increased speed. And yes the stiffer the front spring the more torque is need to engage the drive clutch and this transmits to a more forceful engagement of the rear. All depends on the spring and weight set up the video talks about. That's where the clutch experts come into play on this. Plus not necessary to get a complete kit. Springs for front and rear along with weights are available.
Old Jan 25, 2016 | 04:13 PM
WilliamBos's Avatar
Another place you couldcheck is Dalton Industries.
Dalton | Polaris Main Listing
Old Jan 25, 2016 | 04:38 PM
SOLOLUCKY's Avatar
thanks OPT and WilliamBos...good info and will be checking out Dalton right now
Old Jan 25, 2016 | 04:43 PM
WilliamBos's Avatar
You're welcome. If you email Dalton, they are fast to reply. And with thecurrent exchangerate,you will be money ahead too.
Old Jan 26, 2016 | 02:22 PM
SOLOLUCKY's Avatar
Yeah, I contacted Dalton...and nope they do not make one either...sheesh...and after some soul searching...raising the engagement RPM for an already twitchy engagement quad might not be the best ride-ability choice...Will leave it be for now.
The explanation of how and why it werks the way it does was very helpful tho thanks.
Old Jan 26, 2016 | 03:04 PM
EPi does have the kits,but people have complained about the harsh engagement.Products - ATV / UTV - Clutch Kits - Polaris - 550 - Sportsman - EPI
Stole this from the Polaris Atv Forum from one poster. May or may not help ya..550 XP Harsh clutch engagement fix - Polaris ATV Forum
Old Jan 27, 2016 | 08:57 PM
SOLOLUCKY's Avatar
Thanks OPT, gonna give the silver spring swap a try. From what the video you posted explained it seems like the rear clutch gets a tougher spring when ya do a clutch kit thus reducing slippage. Obviously I will not be swapping anything in that clutch so nothing changed there but I never really noticed slippage excelt in deep nasty mud and turning the tires became tough and I don't do deep thick mud very often....but that is an extreme situation anyway. Reduce or eliminate the harsh engagement and the quad is flawless.
