fixing chinese atv
Old Feb 5, 2016 | 10:26 AM
blaze_master's Avatar
Cool fixing chinese atv
if you bought one or know anything about old Honda's you will know very well the up keep on these motors. if you do it right you can limit your time put into these. the first thing I would do is put in sealed bearings, swap the CDI, change grips is a must, swap shocks, and buy a few different sprockets for riding conditions. if you are lucky you got one with multiple forward gears, if not then trust me and get a few sprockets. exhaust is a must in order to lift it up off the ground I recommend getting the pit bike exhaust. and lastly I would worry about tires. good luck and ride hard
Old Feb 5, 2016 | 10:55 AM
TLC's Avatar
TLC
After all of that I would just get a used name brand and put gas in it and go ride. CDI and shocks are not cheap and you forgot stators they blow out light cheap light bulbs on Asian ATVs.
Just buy something like this used and be done with it.
Old Feb 6, 2016 | 09:06 AM
wrong I did my nephews with all that for a little under $100.00 and now its a beast. never had any problems with stator but that could come up later. parts are cheap and if you know what your doing its easy.
Old Feb 6, 2016 | 03:00 PM
Unsub's Avatar
If youre like me and like to work in the garage these cheap machines are a great way to educate yourself and test your skills.
If you dont mind waiting for parts theyre dirt cheap directly from china.
If youre the kind that want something that just works you obviously need to put more money into it.
Old Feb 7, 2016 | 12:53 AM
greg74's Avatar
or something like this Honda 300 Fourtrax. Those old Honda 300 Fourtrax were great quads.
Old Feb 7, 2016 | 10:47 AM
Zrock's Avatar
Super Quad Patrol
The reason the imports keep blowing electrical is the low quality of the solder joints in wire harness. Pull em apart do em right and it will eliminate most issues on electrical.
Yekrats
May 18, 2016 02:30 PM
mmumm
Dec 25, 2015 10:13 AM
kevron169
Dec 20, 2015 02:05 PM
Timbo2500
Nov 15, 2015 09:02 AM
Shifts
Nov 11, 2015 08:36 PM
