2004 700 Twin Front gearbox
OPT....have you got a supplier for the seals for the front gearbox. When I got into the carb adapter thang..... I found I had the front gearbox was leaking oil.
Pt#3233956....Kit-comes with all the seals and O-rings.
My supplier here in Memphis doesn't handle this. And didn't wont to go to the Polaris dealer here if I could help it.
Also...is there anything I should look for when I get the box out......
mike the out-put hubs?
thanks,
Hump
thanks,
Hump
Cheapest I've found on the seal kit is here.Look at the very bottom of the page.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse See if this video helps. On a Rzr diff but similar.
OPT...check out this site........
Quad Logic | Your intelligent source for ATV parts
seems like good prices too
Hump
Hump
Their site looks pretty good. Both their upgraded plastic and aluminum roller cages are on ebay also. Did notice their complete diff rebuild kit with upgraded cage,bearings,plate and seals for 199 bucks. Might be something to think about if you haven't cracked into your diff before. Sooner or later the cheap oem plastic cages will crack or explode.
KG_97xplorer
Jan 11, 2016 12:44 PM
