Polaris magnum
Old Feb 17, 2016 | 11:09 AM
Boomer Shirah's Avatar
Default Polaris magnum
Atv cranks during a pullstart. Will not start using starter, starter turns etc. but won't crank it))------, after motor cranks using pull start , and afterr it warms up. Motor will crank up using starter, anybody know the cause of this?
Magnum 330 2×4
Old Feb 17, 2016 | 12:52 PM
If you've eliminated a weak battery as a problem,then sounds like the same symptoms that many have had on the 425,500 machines.325 is similar. You can first check resistance on the white and white/red wires leading to the cdi from the pick up coil. Should be around 97 ohms +/- 20%. If it's in range,a slight "adjustment" towards the flywheel may be needed so that it will have strong spark using the electric starter. Look at this members post from awhile back. no spark to plug when using electric starter - Page 3 - ATVConnection.com ATV Enthusiast Community Also dirt and trash on the face of the pick up coil or flywheel can cause problems on cranking also.
RUNMYTA96
Feb 27, 2016 07:24 AM
95 warrior350
Sport Quads
Feb 22, 2016 08:40 AM
Kerabo
1) Engine problems..
Feb 20, 2016 09:51 AM
Ipmcelroy
Feb 17, 2016 05:47 PM
Greasemonkey2067
Feb 15, 2016 03:11 PM
