2002 sportsman 700 front hub axle question
Old Feb 19, 2016 | 06:38 PM
m2cyclone's Avatar
Default 2002 sportsman 700 front hub axle question
currently rebuilding the front end on the 700. new axles, bearings etc...
When I installed the axle into the hub, the axle sticks out of the hub a few mm. When I install the washer and nut, the washer hits the axle not allowing the axle and hub to compress together.
I figured that you would want the axle and hub to be a snug fit and squeeze the strut bearing a little. This way there is no movement or wiggle when riding.
Do I need to drill out the wash a little to clear the axle or is this gap normal.
The washer came with the old bike and not the new axles. And didn't check this on the old setup before I replaced everything.
Also, anyone know the torque specs.
thanks
Old Feb 19, 2016 | 07:44 PM
My 2005 manual calls for 70 foot pounds on the hub nut torque. If it's an aftermarket drive shaft there may be some differences in length.You may have to modify washers,etc to work right. Hub needs to be snug with no wobble.
Old Feb 19, 2016 | 08:30 PM
m2cyclone's Avatar
ok, thanks. thats what I was thinking.
thanks again.
Old Mar 2, 2016 | 05:45 PM
m2cyclone's Avatar
well, finally got to looking at the front axles again and it appears that I need the early version axle that has the splines going all the way to the CV joint. And the ones that I bought, the splines stop about an inch from the cv joint. Which doesn't let the CV fit snug against the Wheel bearing or hub. which allows the wheel/hub to have some free play.
Guess I'll be ordering more..
Too bad the early version is more expensive..
does anyone know a cross reference. Might be cheaper if I search other models and not the 700.
Old Mar 2, 2016 | 06:04 PM
m2cyclone's Avatar
Looks to be cheaper to buy 2 hubs to match.
I'm guessing any front hub from a 2003 and up would work.
I assume the hub bearings didn't change.
Old Mar 2, 2016 | 06:20 PM
Guess you'd be needing this part number then. Later model 2002 hub part number along with other models that used the same hub.
Usage : 5133360
Year Product Model Assembly
2005 ATV ATP 330 4X4 REAR WHEEL DRIVE - A05JD32AA (4995189518C13)
2005 ATV ATP 330 4X4 QUAD REAR WHEEL DRIVE - A05JD32EA (4995189518C13)
2005 ATV ATP 500 4X4 REAR WHEEL DRIVE - A05JD50AA/AB/AC (4995189518C13)
2004 ATV MAGNUM 330 4X4 FRONT WHEEL - A04CD32AA/AB/AC/FB (4987318731B07)
2004 ATV A04CH42AQ SPORTSMAN 400 FRONT WHEEL - A04CH42AQ/AR/AS/AT/AV (4987318731B07)
2004 ATV A04CH50AQ SPORTSMAN 500 FRONT WHEEL - A04CH50AO/AQ/AR/AS/AT/AV/AW/AX (4987318731B07)
2004 ATV A04CH59AF SPORTSMAN 600 FRONT WHEEL - A04CH59AF/AH/AJ/AT/AV (4987318731B07)
2004 ATV A04CH59AK SPORTSMAN 600 FRONT WHEEL - A04CH59AK/AL/AN/AQ/AW (4987318731B07)
2004 ATV A04CH68AC SPORTSMAN 700 FRONT WHEEL - A04CH68AC/AF/AH/AJ/AT/AV (4987318731B07)
2004 ATV A04CH68AK SPORTSMAN 700 FRONT WHEEL - A04CH68AK/AL/AN/AO (4987318731B07)
2004 ATV A04CH68AU/CU SPORTSMAN 700 FRONT WHEEL - A04CH68AP/AQ/AU/CU (4987318731B07)
2004 ATV ATP 330 4X4 FRONT WHEEL - A04JD32AA (4977487748B09)
2004 ATV A04JD50AA ATP 500 4X4 FRONT WHEEL - A04JD50AA/AB/CA (4985938593B09)
2004 ATV ATP 330 4X4 REAR WHEEL DRIVE - A04JD32AA (4995189518C13)
2004 ATV A04JD50AA ATP 500 4X4 REAR WHEEL DRIVE - A04JD50AA/AB/CA (4995189518C13)
2004 ATV MAGNUM 330 2X4 SWING ARM/REAR/GEARCASE MOUNTING - A04CB32AA/FC (4986188618C07)
2004 ATV MAGNUM 330 4X4 SWING ARM/REAR/GEARCASE MOUNTING - A04CD32AA/AB/AC/FB (4986268626D01)
2004 MIL SPORTSMAN 700 MILITARY WHEELS, FRONT - A04CH68MB (4970197019B07)
2003 ATV MAGNUM 330 4X4 FRONT WHEEL - A03CD32AA/AB/AC/FB (4987318731B07)
2003 ATV 500 MAGNUM 4X4 HDS FRONT WHEEL - A03CD50FB (4987318731B07)
2003 ATV SPORTSMAN 700 FRONT WHEEL - A03CH68AA/AC/AF/AH/AL (4987318731B07)
2003 ATV MAGNUM 330 4X4 SWING ARM/REAR GEARCASE MOUNTING - A03CD32AA/AB/AC/FB (4975217521C14)
2003 ATV MAGNUM 330 2X4 SWING ARM/REAR/GEARCASE MOUNTING - A03CB32AA/FC (4975157515C07)
2003 ATV 500 MAGNUM 4X4 HDS SWING ARM/REAR/GEARCASE MOUNTING - A03CD50FB (4975277527C12)
2002 ATV SPORTSMAN 700 FRONT WHEEL - A02CH68AA/AB/AC/CA/CB (4966346634B07)
Strut bearing showed to be the same on 2002 and 2003 models.
Old Mar 2, 2016 | 06:38 PM
m2cyclone's Avatar
thanks for the info, just got 2 hubs for $30. better than $200 for more axles.
I gotta pay more attention for split year models.
Old Mar 3, 2016 | 08:15 AM
Hated before/after certain mfg date parts differences. Just caused confusion with owners and parts suppliers. Hope the hubs works out for you ok.
Old Jun 24, 2020 | 06:29 AM
Tom Paulik's Avatar
Default Part number
What was the part number for the hubs you used I did the same thing on mine and made s spacer but if the updated hubs worked for you I'd like to switch mine thanks
Old Sep 26, 2020 | 09:20 PM
Dustin78's Avatar
I've ran into the same problem, can you just make spacers out of washers or does that cause other issues?
Mauler5
Nov 26, 2016 03:10 PM
mywifesquad
10
Sep 3, 2016 09:07 PM
Bluewar02
CAN-AM (BRP) Ask an Expert!
Feb 20, 2016 07:03 PM
LateStarter
Feb 19, 2016 10:05 AM
