CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
2008 DS70 starter problem
Old Feb 26, 2016 | 07:37 AM
Joshwfl's Avatar
Default 2008 DS70 starter problem
Bike is immaculate, my son rides it easy, and it's always been maintained. I'm at my wits end here. Last ride, he shut it off for a mid trail break. It would not start back up with the electric start, the solenoid just clicked. I dropped in a new battery, no change. The solenoid tested good, but I replaced it anyway with the same result. I pulled the starter and it bench tested fine, but I replaced it anyway. The new starter is experiencing the same issue...it has power when it should, but does not turn when installed. It will fire right up with the kick starter, but I need to solve this problem. Any ideas?
Old Feb 27, 2016 | 06:56 PM
Joshwfl's Avatar
Lots of views.....does anyone know if it has a starter clutch?
Old Feb 27, 2016 | 07:41 PM
Fasteratv's Avatar
Josh....not much activity on this forum for any DS....I'm not sure who actually made this ATV, but it's probably not Bombardia. If its a CVT trans, then pull the left engine cover on it ( as sitting on the ATV ), the older ones did have a starter clutch. Thats more than likely the issue. And, are you sure its an 08?
Old Feb 27, 2016 | 08:13 PM
If it's an 08 shows to have a starter clutch. $121 here. Parts
jeffreybandel
Jan 18, 2016 04:49 PM
ritchierich
1) Engine problems..
Jan 13, 2016 02:57 AM
ATVAdventurer
Where to Ride
Jan 10, 2016 02:00 PM
DGNAZ
ATV Expeditions
Dec 29, 2015 03:27 PM
franzal1
Dec 21, 2015 03:43 AM
