Speedometer not working, 2015 570 sportsman
Old Mar 1, 2016 | 09:30 PM
bmiller59's Avatar
Default Speedometer not working, 2015 570 sportsman
Speedo just stopped working after we got back from AZ. All the other functions in the cluster work fine. It takes two hours to get to the dealer, so I'm hoping it's some little thing I can deal with at home.
Old Mar 2, 2016 | 04:12 AM
Speed sensor has moved from the front caliper bracket on the older models to the gear case on this model. I'd first check that the connections are ok.Could be as simple as unplugging and plugging back up.Plus not a bad idea to check the fuse box also and unplugging the speedo harness for a couple minutes.Might reset. Item #1 on the sensor.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Hard to find a cheap 2015 model service manual,but here's a cheap 5 buck one for the 2014 570. Worth the money if it can keep you from having to haul it to the dealer to find the problem.https://www.tradebit.com/filedetail....al-repair-2014 For the combo 2014-2015 manuals,they're on ebay.2015 Sportsman 570 service manual | eBay
Old Mar 4, 2016 | 07:16 AM
bmiller59's Avatar
Thanks, I'll check that out today. Got a little busy the last few days.
jba
Sep 25, 2016 02:45 PM
Ckieffer29
13
Feb 22, 2016 03:40 PM
old polaris tech
Feb 4, 2016 04:40 PM
