low end sputter (wolverine)
Old Apr 11, 2001 | 10:21 PM
wolv09's Avatar
I own a 2000 wolv and when coasting down a hill in the lower gears thengetting back into the gas 1/4 throttle or less it wants to sputter any ideas it has a dynojet kit fmf pipe and moose air filter what to do
Old Apr 12, 2001 | 02:01 AM
BigMud2000's Avatar
Check your jetting, it's probably incorrect, after you've run it awhile, pull the spark plug and check it, adjust your jetting accordingly.
Old Apr 12, 2001 | 07:26 AM
wolv09's Avatar
this is how I currently have the carb set up main 147.5 pilot screw 2 turns out and needle set in the middle where next??
Old Apr 12, 2001 | 09:43 AM
bermbanger's Avatar
Check the plug. If its black your rich.Lean the clip or drop the main or maybe adjust the pilot screw.But if your miss is right a 1/4 throttle its not the main. its the pilot jet, not screw. If your plug is white or maybe grey you are lean. I think you are lean so i would suggest to go up one on the pilot jet. if the plug says it's lean. If you went to rich with the main it could be rich. Lower the clip to take a chance and see if thats enough. I think you are lean tho.
ReconBayou
Oct 31, 2022 05:37 PM
ltrmc02
Aug 22, 2021 02:34 PM
Bernhard
Sep 25, 2015 12:45 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Hw00d
Sep 10, 2015 08:53 AM
