Replacing can shaft on 1999 Polaris scrambler 500
Old Mar 4, 2016 | 11:21 AM
Barnsnelbon's Avatar
Default Replacing can shaft on 1999 Polaris scrambler 500
So my cam shaft is shot the exhaust can lob is worn down heavily so I'm replacing it. Is there anything else I should do while Iv got it apart
Old Mar 4, 2016 | 02:50 PM
1ArmBandit's Avatar
replace at least the exhuast rocker and inspect the intake..while i was in there id take a peek down in your cylinder, look at the walls and piston just to make sure nothin funny is going on in there
Old Mar 4, 2016 | 03:27 PM
Plenty of cams and rocker arms on ebay.Sportsman 500 cam | eBay Pull the tank screen as it will probably have metal shavings on it. Don't forget to drain the engine sump and clamp off the tank vent hose when the engine is ready to start up with the new parts.Get a small tube of assembly lube for the new cam's lobes and journals.
Old Mar 4, 2016 | 06:25 PM
hydrex's Avatar
If you have to replace anyway, why not replace with a hotter cam? I run a Web Racing Cam in my Arctic Cat 500. Quite a nice improvement in performance. I broke in the new cam with straight 30W at 2000rpms and slightly more for 30 min as Web suggested, before draining and replacing with RotellaT6 .
Old Mar 4, 2016 | 10:27 PM
user493's Avatar
Moto Psycho
I took a look at Web racing cams catalog that hasn't been updated since 2013. The Sportsman 500 cams require a high compression piston and don't have a compression release. That would make it hard to pull start which is something I've had to do with mine. An H.O. cam would be good enough for me.
Old Mar 5, 2016 | 01:49 AM
1ArmBandit's Avatar
Old Mar 5, 2016 | 02:47 PM
Originally Posted by 1ArmBandit
+1
DennisZ
Feb 22, 2016 12:09 PM
Kazjag500
Feb 11, 2016 10:19 PM
