Will not run
Old Mar 23, 2016 | 01:28 PM
Msantana's Avatar
Default Will not run
Hi everybody,i have an 04 polaris 500 ho AWD auto playin in the mud it die on me now it wont start i check spark plug and it does fire & also cleaned carburator and nothing turns over fine but will not start
Need all advice i can get
Old Mar 23, 2016 | 02:59 PM
Gotta have spark, fuel,air,compression(55-90 psi on average) Pull the fuel line from the carb and crank the engine over. Should be a steady or pulsing stream if the fuel pump is ok. Plus ecm or regulator/rectifier model? Can make a difference if it's an ecm model as they can screw up everything if they fail. Plus can you pull start it? If you can,spark may be too weak with electric starter. You can check for dirt/mud around the pick up coil and flywheel plus check that the pick up coil is around .020 away from the raised section on the flywheel.Manual call for between .016-.040. Last thing I'd still check all connections and use niogel grease to help keep moisture out.Hope some of this helps you find the problem.
mvorpahl
Feb 6, 2017 11:31 PM
archaicseahorse
Feb 7, 2016 02:08 PM
TaoTao110D
Jan 21, 2016 01:23 AM
cornermike
Jan 18, 2016 01:54 PM
Jan 10, 2016 05:05 PM
