sportsman clutch
Old Apr 19, 2016 | 08:52 PM
Fubar008's Avatar
Default sportsman clutch
I recently acquired a 1999 sportsman 500 with ebs. It did not run and had been sitting for years, I got it running and it actually runs really good but does not move. The primary clutch is junk, completely seized up. i was going to rebuild it until i tried to remove the pivot pins and there rusted in and will probably need to be drilled out. It seems more cost effective to just get a good used clutch. I have been searching for a used clutch but i'm not sure what years and models are compatible and if having EBS matters? Thanks
Old Apr 19, 2016 | 09:18 PM
if you'd rather have a non ebs clutch system,you have to change the driven clutch along with the drive clutch or you will have problems.
A lot of different models shared the same part number of the drive clutch on your model. A used one from any of these would work,but expext to have to replace the fiber washers,etc on any used clutch
Usage : 1520231 Drive Clutch
Year Product Model Assembly
SERIES 10 PPS PTV 4X4 DRIVE CLUTCH - C10CD50AA (4977417741C04)
2007 MIL SPORTSMAN 700 MV CLUTCH, DRIVE - A07MH68MA/ME (4999609960C09)
2005 ATV ATP 500 4X4 DRIVE CLUTCH - A05JD50AA/AB/AC (4995189518C10)
2005 ATV SPORTSMAN 500 HO/INTL DRIVE CLUTCH - A05MH50AB/AC/AG/AH/AL/AT/FB (4994279427C10)
2005 ATV SPORTSMAN 600 DRIVE CLUTCH - A05MH59AK/AN (4994279427C10)
2005 ATV SPORTSMAN 700 EFI DRIVE CLUTCH - A05MH68AC/AS/AT/AU/AW (4994279427C10)
2005 ATV SPORTSMAN 700 DRIVE CLUTCH - A05MH68AK/AN/AD (4994279427C10)
2005 ATV SPORTSMAN MV7 DRIVE CLUTCH - A05MH68AP (4994279427C10)
2005 MIL SPORTSMAN MV 7 DRIVE CLUTCH - A05MH68MB (4999609960C09)
2004 ATV MAGNUM 330 4X4 DRIVE CLUTCH - A04CD32AA/AB/AC/FB (4986268626C03)
2004 ATV A04CH50AA SPORTSMAN 500 DRIVE CLUTCH - A04CH50AA/AC/AE/AG (4987288728C06)
2004 ATV A04CH50AQ SPORTSMAN 500 DRIVE CLUTCH - A04CH50AO/AQ/AR/AS/AT/AV/AW/AX (4987288728C06)
2004 ATV A04CH59AF SPORTSMAN 600 DRIVE CLUTCH - A04CH59AF/AH/AJ/AT/AV (4994279427C10)
2004 ATV A04CH59AK SPORTSMAN 600 DRIVE CLUTCH - A04CH59AK/AL/AN/AQ/AW (4994279427C10)
2004 ATV A04CH68AC SPORTSMAN 700 DRIVE CLUTCH - A04CH68AC/AF/AH/AJ/AT/AV (4987468746C03)
2004 ATV A04CH68AK SPORTSMAN 700 DRIVE CLUTCH - A04CH68AK/AL/AN/AO (4987468746C03)
2004 ATV A04CH68AU/CU SPORTSMAN 700 DRIVE CLUTCH - A04CH68AP/AQ/AU/CU (4987468746C03)
2004 ATV A04JD50AA ATP 500 4X4 DRIVE CLUTCH - A04JD50AA/AB/CA (4995189518C10)
2004 MIL SPORTSMAN 700 MILITARY DRIVE CLUTCH - A04CH68MB (4986128612C03)
2003 ATV MAGNUM 330 4X4 DRIVE CLUTCH - A03CD32AA/AB/AC/FB (4975217521C02)
2003 ATV 500 MAGNUM 4X4 HDS DRIVE CLUTCH - A03CD50FB (4975277527C03)
2003 ATV SPORTSMAN 500 HO DRIVE CLUTCH - A03CH50AA/AB/AC/AD/AE/AH/AJ (4987288728C06)
2003 ATV SPORTSMAN 600 DRIVE CLUTCH - A03CH59AA/AF/AG (4994279427C10)
2003 ATV SPORTSMAN 700 DRIVE CLUTCH - A03CH68AA/AC/AF/AH/AL (4987468746C03)
2002 ATV MAGNUM 500 2X4 HDS DRIVE CLUTCH - A02CB50FC (4974857485B12)
2002 ATV MAGNUM 325 4X4 DRIVE CLUTCH - A02CD32AA/AB/AC/FB (4970147014C05)
2002 ATV 325 MAGNUM 4X4 HDS DRIVE CLUTCH - A02CD32AA/AB/AC/FB (4970147014C05)
2002 ATV MAGNUM 325 4X4 FREEDOM DRIVE CLUTCH - A02CD32AA/AB/AC/FB (4970147014C05)
2002 ATV MAGNUM 500 DRIVE CLUTCH - A02CD50AA/AB/FB (4970197019C05)
2002 ATV MAGNUM 500 RMK DRIVE CLUTCH - A02CD50AA/AB/FB (4970197019C05)
2002 ATV 500 MAGNUM VL HDS DRIVE CLUTCH - A02CD50AA/AB/FB (4970197019C05)
2002 ATV SPORTSMAN 500 ALL OPTIONS DRIVE CLUTCH - A02CH50 ALL OPTIONS (4967436743C05)
2002 ATV SPORTSMAN 700 DRIVE CLUTCH - A02CH68AA/AB/AC/CA/CB (4966346634C01)
2002 PPS ATV PRO 500 4X4 PPS DRIVE CLUTCH - C02CD50AC (4972407240C04)
2001 ATV MAGNUM 325 4X4 DRIVE CLUTCH - A00CD32AA (4964026402C004)
2001 ATV MAGNUM 325 4X4 MOSE DRIVE CLUTCH - A00CD32AA (4964026402C004)
2001 ATV 325 MAGNUM 4X4 HDS DRIVE CLUTCH - A00CD32AA (4964026402C004)
2001 ATV MAGNUM 500 DRIVE CLUTCH - A01CD50AA (4964196419C003)
2001 ATV 500 MAGNUM 500 HDS DRIVE CLUTCH - A01CD50AA (4964196419C003)
2001 ATV SPORTSMAN 500 HO DRIVE CLUTCH - A01CH50AA (4964466446C002)
2001 ATV SPORTSMAN 500 DUSE HO DRIVE CLUTCH - A01CH50AA (4964466446C002)
2001 ATV SPORTSMAN 500 RSE HO DRIVE CLUTCH - A01CH50AA (4964466446C002)
2001 ATV WORKER 500 DRIVE CLUTCH - A01CH50AA (4964466446C002)
2001 ATV SPORTSMAN 500 DUSE DRIVE CLUTCH - A01CH50AD (4960026002C002)
2001 ATV DIESEL DRIVE CLUTCH - A10CH46CA (4964376437B014)
2000 ATV MAGNUM 325 4X4 DRIVE CLUTCH - A00CD32FA (4949404940C001)
COwen
Aug 1, 2016 07:52 PM
palsdot
Apr 26, 2016 09:53 AM
Meyerz400
Mar 25, 2016 08:19 PM
GoinCrzyWanaCom
Mar 23, 2016 04:19 AM
INEEDHELPPLZ
Mar 22, 2016 06:40 AM
