New battery location on 570
Old Apr 21, 2016 | 11:24 PM
RticKwad's Avatar
Runs Stealth!
Default New battery location on 570
Thoughts and opinions on new location of the battery? I'm wondering why? Seems a bit exposed to me. What is the improvement gained? Operator access is going to be more intrusive for sure.
Thanks,
R'
Old Apr 22, 2016 | 04:09 AM
Had the battery down there on the X2 back in 2007 iirc. A little inconvenient when it came to changing one out,but most did ok. Main thing is to have battery tinder leads so it will last and always remove the neg lead first when removing the battery,hook up the positive lead first when installing one. That way you wont have to worry about wrench spark if it hits the frame.
Old Apr 22, 2016 | 08:11 AM
greg74's Avatar
I've seen this discussed before. I guess it looks like a terrible location but in reality, it doesn't seem to be much of a problem. I just think under the seat is the ideal location for any atv battery and should be pretty much universal for all brands.
Old Apr 22, 2016 | 11:52 AM
user493's Avatar
Moto Psycho
Under the front rack is a good location too. It only takes a few seconds to take the rack off my friends' 850 or 1,000 Sportsman. But it doesn't seem to cause any problems where it is on the 570. It can't be any worse than under the rear fender covered with mud and that's never been a problem for me.
Old Apr 22, 2016 | 06:06 PM
WilliamBos's Avatar
That's a better location than the older value models, left rear wheel well is a nasty spot.
Ride and enjoy it, your battery will be fine.
Old Apr 22, 2016 | 07:20 PM
Kymco 450i's Avatar
OK....so my eyes are getting old.....however I don't see a battery in that picture! I know probably some sort of optical illusion but...can someone point out the battery before I go nuts trying to find it?
Old Apr 22, 2016 | 08:55 PM
RticKwad's Avatar
Runs Stealth!
Kymco, it's behind the rad reservoir. Of viewing on computer make image larger if on mobile stretch the picture may help a little.
R'
Old Apr 22, 2016 | 09:29 PM
Kymco 450i's Avatar
OK thanks, I was going nuts trying to find a battery in there. Do have to agree with you there, I would not care for it down there either, seems like it would pick up road crud while riding.
Old Apr 24, 2016 | 04:22 PM
RticKwad's Avatar
Runs Stealth!
May I can understand to center the weight some but after pulling it out yesterday trying to reach the battery at least on the left side pictured above is near impossible. I can see having to raise this up to get to it.
R'
Old Apr 29, 2016 | 01:19 AM
switzomatic's Avatar
Never had any battery issues on my wife's 570. Much easier to remove/install with the tire off.
